will Carsound(magnaflow) high flow cat on EM1 pass smog???
Old 01-05-2008, 04:53 PM
YoungMoneySi's Avatar
Default will Carsound(magnaflow) high flow cat on EM1 pass smog???
whuttup guys! i wanna get a carsound high flow cat for my em1 and wanted to know if it would pass smog here in Cali? i know they say it is illegal to change your stock cat for a high flow cat for all obd2 vehicles but i wanted to know if i slapped on a high flow cat would it pass smog??
thanks guy!!
Old 01-05-2008, 05:30 PM
shookones2's Avatar
Default Re: will Carsound(magnaflow) high flow cat on EM1 pass smog??? (YoungMoneySi)
it should still be able to. ask carsound
Old 01-05-2008, 05:33 PM
Luserkid's Avatar
Default Re: will Carsound(magnaflow) high flow cat on EM1 pass smog??? (shookones2)
It will pass visual, sniffer is up to the rest of the car.
Old 01-05-2008, 07:55 PM
zerovandez's Avatar
Carsound/Maganaflow makes catalytic converters specifically for California. These are intended for OEM replacements and not performance. Make sure you get one of those instead of the regular high flow models to ensure you will pass the sniffer.
Old 01-05-2008, 07:59 PM
97Ej6mike's Avatar
Default Re: (zerovandez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zerovandez &raquo;</TD></TR><TR><TD CLASS="quote">Carsound/Maganaflow makes catalytic converters specifically for California. These are intended for OEM replacements and not performance. Make sure you get one of those instead of the regular high flow models to ensure you will pass the sniffer.</TD></TR></TABLE>
That is true, but even with an OEM cat, if your motor is running bad, you can still fail for high NOX levels.
Old 01-06-2008, 09:47 AM
Default Re: (97Ej6mike)
so if i get a direct replacement high flow cat it wont make any additional power? so what is the point of a high flow cat?
Old 01-10-2008, 09:00 PM
shookones2's Avatar
you slightly increase your hp with highflow cat. the main difference of a high flow and a oem is the material that is used within the cat. highflows generally have less restrictive parts within the cat but at the same time also filter's it out like a normal cat. less restriction= "high flow"
Old 05-25-2008, 05:45 PM
datssoled's Avatar
Default Re: (shookones2)
would a megapower skunk2 full catback pass smog in ca?
Old 05-25-2008, 06:00 PM
97Ej6mike's Avatar
Default Re: (datssoled)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by datssoled &raquo;</TD></TR><TR><TD CLASS="quote">would a megapower skunk2 full catback pass smog in ca?</TD></TR></TABLE>
Exhaust doesnt have to do with emissions, it has to do with sound. Sound is questionable for passing. Emissions has to do with what CAT is being used.
88turdbucket
01-27-2005 08:58 PM
Thrillhouse
07-22-2003 07:55 AM
b00sted4dr
02-28-2003 03:53 PM
HBCthugg
05-03-2002 11:50 PM
Quick Reply: will Carsound(magnaflow) high flow cat on EM1 pass smog???
