Need help/suggestions on front end vibration
I have searched numerous threads on this issue but still cannot find the cause my front end vibrations.
run down on my set up
b18 swap in 94 coupe
brand new ebay swap mounts
brand new advance auto axels (the axles I just replaced with a new set as I though the axles may have been the cause)
I am getting a pretty good vibration in my door panels and dash/steering wheel from about 2500-4000 rpm under accel. Full throttle no vibrations are felt it seems to be under slight accel. Swap my advance auto axles for a new set today did not solve the issue. All other suspension components seem ok, but my shocks are blow on skunk 2 coilovers. Any ideas here? Maybe the intermediate shaft? could it be the blown shocks? Or is it typical to get vibrations from solid mounts?
Any help would be great
Re: Need help/suggestions on front end vibration (joshb_)
you should get vibrations from a good solid aftermarket motor mount. I had hasports in my teggy which caused alot of vibration it was normaly when i was at idle though. So if i had to take a guess eather your mounts are doing there job and thats y its vibrating or they could just be bad mounts ebay stuff isent always that great. I just bought some innovative motor mounts they where much cheaper then hasports and seem to be good quality although i havent drivin with them yet.
mine is exactly the same.......after i threw in the new motor mounts(probably most likly your mounts)
Re: (RonJ@HT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RonJ@HT »</TD></TR><TR><TD CLASS="quote">Might your wheels be out of balance?</TD></TR></TABLE>
I don't think so, it does not change when I rotate my tires and they were last balanced about 5 months ago and I don't drive the car a whole lot.
IVGattaBeDreaming
11
09-05-2006 11:42 AM
