B16a2 into EJ, mounts?
Probably a dumb question but was wondering if the motor mounts are the same. The car is a '99 civic coupe, ex model so it should be plug and play but I needed to know if the stock d16 mounts can be used.
Also on the stock d16 clutch slave cylinder, can the line be reused on the b16, as in the line that runs to the cylinder?
Re: B16a2 into EJ, mounts? (krucial7integra)
i think the only mount you need to change is the rear one i think you need one off of a SI , and i do believe that the slave and lie will work,
This is what you need. You will need the rear bracket and the block mount.
http://cgi.ebay.com/ebaymotors...&rd=1
EM1 Resto
09-24-2009 01:28 PM
NINJASPY
09-14-2003 03:25 PM
