shift linkage help
shift linkage help
ok i got a 98 coupe ex and i put a 97 dx engine in it out of a hatch witch shift linkages should fit in i had a b20 in it and those are too long any advise is good thanks
Re: shift linkage help (fudo1252)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">94-01 Integra or 99-00 Si</TD></TR></TABLE>
^if you have a b-series
if you have a d-series
doesn't matter what trim you get it from cx/dx/lx/ex 96-00
If I'm not mistaken you will need a D-series or stock shift linkage to go in replacement (hence your b swapped linkage being too long). Between models should not matter as the d-series trans are interchangable.
