Old 03-25-2015, 09:52 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
Print Wikipost
DYI: Remove TPS (throttle position sensor)
Old 01-07-2008, 01:43 PM
polything's Avatar
Default DYI: Remove TPS (throttle position sensor)
Okey. i searched, nothing came up.
So here we go:
How to remove d-series TPS from TB
Tools:
1. You finger: to turn the screw
2. A fine screwdriver or anything of this sort
3. 3 pounds hammer or small one is good
Victim:
Old TPS on the old TB.
Why:
Your current TPS is broken or stop working and you dont want to buy a new TB (>$200).
Honda doesnt sell the sensor itself, plus they dont want us to take it apart. The only way to get another TPS sensor is to hack it off another TB.
How to:
Put the screwdriver in the position as pictured above (45 or 90 degree)
The screw will turn very easily (using your finger) once you gently tap it counter-clockwise.
You should get that. Remember, this screw was designed to be screwed by your finger
Now go to auto parts store and get the new screw (m5-.8) and reuse the 2 washers.
Next you need to tune the TPS so it could work well on your car (set up) <<<I dont know how to do this. Some one should do a write up on that.
Good luck! There you have it.
I dont know where to post this. Mods plz more me to the appropriate section.
polything is offline
Old 01-07-2008, 01:53 PM
pdiggitydogg's Avatar
You need to connect a multimeter to the tps and move the sensor around until the correct ohm specs are achieved.
With the TB closed, sensor disconnected, ign off:
Pins 1 and 2 = 0.5-0.9ohms
Pins 2 and 3 = 3.6-5.4ohms
You also need to be sure you have correct voltage, sensor connected, ign 'on':
Pins 1 and 3
0.5volts with the TB closed
4.5volts with the TB fully open
These specs should also be correct from the factory. If theyre not, and you havent replaced the tps, you know its time to do so.
If you have replaced the tps and these readings arent met, your sensor isnt positioned properly
pdiggitydogg is offline
Old 01-07-2008, 02:13 PM
slow_cx's Avatar
Good info! I Had to figure this out for myself once too.
slow_cx is offline
Old 01-07-2008, 02:38 PM
polything's Avatar
Default Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">You need to connect a multimeter to the tps and move the sensor around until the correct ohm specs are achieved.
Pins 1 and 3
If you have replaced the tps and these readings arent met, your sensor isnt positioned properly</TD></TR></TABLE>
so its all about moving it around and get the correct ohms.
imma go buy a multimeter now )
Old 01-07-2008, 02:41 PM
suspendedHatch's Avatar
Default Re: (polything)
Where are you going to get a new tps gasket?
suspendedHatch is offline
Old 01-07-2008, 05:41 PM
polything's Avatar
You would need to CAREFULLY remove the old paper gasket. and reuse it.
Old 01-07-2008, 05:43 PM
Dramier's Avatar
FYI, an automatic punch works much better than a bigass hammer coupled with a little *** screwdriver.
Good write-up!
Dramier is offline
Old 01-07-2008, 05:45 PM
Bejita's Avatar
My way is by far the easiest. Take a hacksaw blade and cut a slit into the middle of the head. Then use a flat head screwdriver to take em right out. Its easy...the metal is soft.
Bejita is offline
Old 01-07-2008, 05:48 PM
Dramier's Avatar
Default Re: (Bejita)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bejita &raquo;</TD></TR><TR><TD CLASS="quote">My way is by far the easiest. Take a hacksaw blade and cut a slit into the middle of the head. Then use a flat head screwdriver to take em right out. Its easy...the metal is soft.</TD></TR></TABLE>
Nope. Automatic punch FTW! No work at all. Push, click, turn with finger.
Dramier is offline
Old 01-07-2008, 08:24 PM
ejoner's Avatar
Default Re: (Dramier)
Or a dremel with a cut off wheel, easier to work with if you don't wanna remove the tb.
ejoner is offline
Old 01-08-2008, 07:30 AM
JDM92da6's Avatar
Default Re: (ejoner)
i agree,ie always used a dremel and notched the screw and completed with a flat head
JDM92da6 is offline
Old 01-08-2008, 07:41 AM
shookones2's Avatar
Default Re: DYI: Remove TPS (polything)
very nice. i just figured this out on my own the other day! wish i had saw this sooner
shookones2 is offline
Old 01-08-2008, 07:58 AM
polything's Avatar
my way or my friend's way of doing this is NOT the easiest one.
YET, no one ever does a write up on how to do it.
good info though.
Old 02-22-2008, 10:47 AM
obuhmyuh's Avatar
Are b and d-series tps units interchangeable??
edit: http://www.iapdirect.com/pictu...s.pdf &lt;-- great instructions as well
obuhmyuh is offline
Old 01-26-2009, 12:12 AM
googoodc's Avatar
Default Re: DYI: Remove TPS (throttle position sensor)
yes honda doesnt make new tps but there are other companys and here is a linkt to one and i know that ebay has them and blox makes them too and they come with gaskets
http://www.streetimports.com/product_details.asp?id=991
googoodc is offline
Old 01-26-2009, 03:01 AM
2k_Si's Avatar
I saw a skunk2 video on replacing the throttle body. In that video he calibrated the tps outside of the car. How good does that work?
2k_Si is offline
Old 01-26-2009, 08:28 AM
b16racereg6's Avatar
i use miny vicegrips to take them screws off mad easy just pinch and twist and bam they off and yeah only took me about 2 or 3 striped ones to learn that lol
b16racereg6 is offline
Old 01-26-2009, 08:36 AM
Cool Cool Island Breezes. BOY-EE
B serious's Avatar
As long as you get the correct voltage supplied to it...it doesn't matter where you calibrate it. In the car, on the moon, whatever.
B serious is offline
Old 01-26-2009, 08:40 AM
2k_Si's Avatar
Originally Posted by b serious
as long as you get the correct voltage supplied to it...it doesn't matter where you calibrate it. In the car, on the moon, whatever.
thank you for the reply
2k_Si is offline
Old 01-26-2009, 09:21 AM
CRX30436's Avatar
good write up. i use the same method but instead of a small screwdriver, i use a reagular flat head screwdriver and any thing that is heavy enough to give the screw a lil persuasion and your done!!
CRX30436 is offline
Old 01-26-2009, 09:30 AM
teamworxek9's Avatar
small vice grips for the win. then i just go to my handy honda bolt drawer and find a screw. make sure you use some loctite.
teamworxek9 is offline
Old 07-07-2010, 09:10 PM
Rob.'s Avatar
good info
Rob. is offline
Old 09-30-2010, 03:34 PM
pjschmitt's Avatar
I used a 3/4 inch old wood chisel. It made a notch and turned it at the same time. Being a carpenter has its advantages sometimes, especially when it comes to tool variety.
It doesn't matter how you get it off, we re al just trying to help each other out here right? So I found some sites here and there for adjusting the TPS for the H22 and they were the same method.
TPS can be calibrated off the engine. I understand the question because it is a pain to get at those bolts. I happened to have a set of 1/4, 3/8 and 1/2" star tool sockets which helped me. A tiny 1/4" ratchet made a big difference. Aslo it had a lock position that allowed me to tighten and loosen with flipping the switch.
A while back I used some strippers and spread the wires open a little like I was stripping them and took another piece of wire and stripped it too, then I wrapped it around the exposes wire. Did this on all three, that way I could easily manipulate the TPS while another person handled the meter. I got this idea from seeing someone attach splicers that allow you to keep you wire intact and tehn have a second wire connected to it with a bullet style connector.
My method was good for the whole thing while installed in the car. But after done, I had to remove them and tape the wires back up. I guess I cold have depinned and used heatshrink, but I just taped and loomed it.
This is a great string / thread / posting whatever.
pjschmitt is offline
Old 07-27-2012, 08:23 AM
netplaceus's Avatar
I called them, they do not make it anymore. Not a big enough market anymore I guess, back to the junk yards!
netplaceus is offline
DCxMagus
05-03-2007 06:45 AM
cazper8890
03-02-2007 08:25 PM
ninjaman
07-21-2003 01:02 PM
rasta420
17
04-11-2003 02:24 PM
unFOB4U
08-30-2001 10:58 AM
Quick Reply: DYI: Remove TPS (throttle position sensor)
