MAP SENSOR PROBLEM..
Old Jan 5, 2008 | 08:57 PM
eg2tr's Avatar
Default MAP SENSOR PROBLEM..
my MAP SENSOR keeps on failing and keeps making my check engine light to come on..i tried several options on trying to fix it..i replaced it about 5 times already and yet the check engine light still keeps on coming on..when I rev it at about 7600 thats whenever the light comes on..I tried reseting the ECU but it still came on...hardwired the wires directly to the ECU and still F*kn comes on...what other options do I have? or what seems to be the problem?
Old Jan 5, 2008 | 09:09 PM
z6hatchboy's Avatar
Default Re: MAP SENSOR PROBLEM.. (eg2tr)
Have you swapped recently or something, and the map + tps wires mixed up?
Old Jan 5, 2008 | 09:12 PM
Chiovnidca's Avatar
Honda map sensors rarely crap out. I'd be looking for a wiring, pin fit, or ecu problem. Might want to check the t-stat ground also.
Old Jan 5, 2008 | 09:17 PM
EG6 Poe's Avatar
Default Re: MAP SENSOR PROBLEM.. (z6hatchboy)
I 2nd This!!!!
Old Jan 5, 2008 | 09:36 PM
eg2tr's Avatar
i just recently did a swap...b18c..im runnin too rich as well... it's not a hard code so im assuming its the map.. but today when i ran it hard the check engine light came on and i turn the ignition off..when i turned it on again it ran sluggish ... i have rewired everything.. i don't think the wires was mixed up coz the car the motor/ecu came off of runs fine... very frustrating coz i can't run the car hard like how i want it to. anything else i can do?
liftdhatch95
Dec 24, 2007 12:17 PM
eg:R
Dec 21, 2006 03:14 PM
Xsi
Sep 23, 2002 07:50 AM
