distributor ?
Re: distributor ? (94EG8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94EG8 »</TD></TR><TR><TD CLASS="quote">If you have the OBD1 GS-R distributor as well you can take both apart and just swap the CYP/CKP/TDC sensors.</TD></TR></TABLE>
If he puts the gsr internals into the Ex distributor it won't bolt up to his motor, and then he still has to worry about the plugs on the obd1 distributor and obd2 harness not hooking up ..... you could take and re pin ur gsr distributor and put ur obd2 plugs on it.
Seagull Management
Re: distributor ? (iamthefollower)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iamthefollower »</TD></TR><TR><TD CLASS="quote">If he puts the gsr internals into the Ex distributor it won't bolt up to his motor, and then he still has to worry about the plugs on the obd1 distributor and obd2 harness not hooking up ..... you could take and re pin ur gsr distributor and put ur obd2 plugs on it.</TD></TR></TABLE>
Thats not what I meant. I meant take the OBD2 EX CYP/CKP/TDC sensors and swap them into the OBD1 GS-R distributor case. I've done the reverse before, It works fine.
yeah but the plugs on the Gsr distributor still won't plug into his engine harness, considering the gsr distributor is obd1 and his engine harness is obd2
unless ur talking about taking out everything and swapping it into the gsr case, I'm sorry i misread what was typed ... ur correct ..
Seagull Management
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iamthefollower »</TD></TR><TR><TD CLASS="quote">yeah but the plugs on the Gsr distributor still won't plug into his engine harness, considering the gsr distributor is obd1 and his engine harness is obd2</TD></TR></TABLE>
Thats why I told him to swap the CYP/CKP/TDC sensors. You know the ones those plugs are attached to. Depining doesn't work either, i've tried, the pins are just slightly different and they wont snap into the plug shell.
Seagull Management
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iamthefollower »</TD></TR><TR><TD CLASS="quote">unless ur talking about taking out everything and swapping it into the gsr case, I'm sorry i misread what was typed ... ur correct ..</TD></TR></TABLE>
Yup
Yup
that sucks man, i've repinned an obd1 distributor to work on a obd0 motor, havn't really messed with the obd2 stuff.. Sorry again though .
Hey man, if you do that with the distributor... what would you take for the gsr internals after taking them out??? I am currently needing a few things to finish build my distributor.
i donno i might even just buy a new one but the OBD1 one i have is bran new less than 500 miles on it and paid 190 for it
Re: distributor ? (xft)
just get a dizzy jumper harness, 30 bucks and you aint gotta do nuttin but snap it in
they have both obd1 dizzy to obd2 harness or vise versa
http://passwordjdm.com/Passwor....aspx
Re: distributor ? (B16aCRXSi)
do u no where i can get a new or uncut civic ex engine wiring harness cuz the one that came in my shell is hacked to ****
poorman's type-r
07-11-2006 01:47 PM
