Several questions...
Will a cf hood for a 95 coupe fit a 95 hatchback, and vice versa?
Will a cf front bumper lip for a 95 coupe fit a 95 hatchback, and vice versa?
Can you simply unplug and remove a cruise control, or is there more to it?
Can you unplug and remove A/C and still be able to use the heater?
Will aftermarket radiator hoses for a D16 (SOHC) fit a B16a (DOHC)?
Where can you find aftermarket valve covers for a SOHC engine? (looked everywhere, cant find any)
Thanks
Thanks
Re: Several questions... (civics4lyfe)
i think there will be no problem by taking off the AC and keep heater working.
what kind of aftermarket valve covers are you looking? maybe if you google it you will find something.
Unplugging the cruise control at the actuator (under the hood) should not cause a CEL light nor any other malfunction. (I am adding cruise control to my 93 DX and so have studied the wiring diagrams and actual parts pretty closely.)
Agreed with rcfranky about the a/c. You might want to remove the evaporator housing (Under the glove compartment) at some point. Air flow will be better.
Re: Several questions... (honda.lioness)
everything from the front end of a coupe and a hatch are the same from fenders to the bumper, i took out every single bit of my A/C and my heater blows even hotter without all that junk, and as far as cruise control, im pretty sure you aint gonna have any problems with it, also have a hatchback
stickyfingers
03-15-2004 06:39 AM
stealthteg
10-08-2002 12:49 PM
