unervsial o2 sensor questions??
so i had to replace my o2 sensor and the oem part was exspensive so i boght a unervsial o2 sensor so i go home and i'm going to put but theirs only one wire on the unervsial one and the four on the original one ..................... do i rewire them cuz the guy at az said not to rewire them.......................can i rewire the original one to fit the unerv.?????
be careful with cheap o2 sensors, many have said they are complete waste of money.
as for your question, I have no answer but havent heard of a one wire universal - I thought the only different was whether you had to solder the wires or get an adapter already on the sensor
Seagull Management
Re: unervsial o2 sensor questions?? (bam69icp)
Either get a 4 wire universal (the single wire are unheated, the 4 wire are heated.) or better yet get a Denso or NTK O2 sensor for your application.
You can't use that one wire sensor. Take it back and get a 4 wire. Or you can ride around with ur car running like sh*t, until u can get one with a plug. That's what i did.
Re: unervsial o2 sensor questions?? (94EG8)
i bought a bosch from advance and it plugs directly in...exactly like the honda one. idk how well it works since my car is STILL running rich for some retarded reason.
