driver side window falls off track wtf
Old 10-22-2008, 05:42 AM
JDMfan77's Avatar
Default driver side window falls off track wtf
does anyone have the same problem it never stays on track pisses me off i heard its common in civics anyone no how to fix it
Old 10-22-2008, 05:56 AM
cinci00si's Avatar
Default Re: driver side window falls off track wtf (JDMfan77)
its a honda thing, take armoral or wd40 and spray it on the rail it will help a lot. you can also adjust the lower bolt near the speaker housing. armoral works the best though.
Old 10-22-2008, 07:09 AM
maxpower98's Avatar
its also pretty normal if the window comes off track only when rolled all the way down. the bushings in the regulator wear out. the window regulators are super cheap i would jsut replace it.
Old 10-22-2008, 07:39 AM
unsungfate's Avatar
OMG ... this happens SO MUCH that i didnt even put my speaker back in the door. but i noticed tat i went ALL of summer without it falling of its track.. and then one foggy and wet night it falls off... AAHH. but at least its an easy fix...
Old 10-23-2008, 06:48 PM
mattkins91's Avatar
omg this makes me so made its even made my window seals to rip.
Old 10-23-2008, 11:01 PM
jdp1978's Avatar
happened to mine it was just one of the bolts in the door came loose .Its one of the bolts that holds th rail in place .Might want to check that out quick fix. Also there are 2 holes in the door where a ratchet goes in no need to take out the speaker . just line the holes up where you can get the tool in fixed in 5min. Good luck with the problem.
Old 10-23-2008, 11:25 PM
andoxviii's Avatar
This is a writeup on this issue:
https://honda-tech.com/zerothread/2061336
The FAQ thread is stickied at the top of the forum...it has all of these common little problems solved.
Old 10-24-2008, 05:40 AM
tercel95's Avatar
Happens all the time, there are a gazillion threads on this. Please search next time...
Old 10-24-2008, 02:21 PM
H-T White Ops
NOFX's Avatar
Default FV-QR
Silicone spray is the best stuff to use btw.
Old 10-24-2008, 02:24 PM
JDMfan77's Avatar
Default Re: (tercel95)
well im new to this website so i dont no how to do all that yet chill the [freak] out and ignore this if u seen so many times
Old 10-24-2008, 02:26 PM
JDMfan77's Avatar
Default Re: (JDMfan77)
red
Old 08-01-2015, 01:00 PM
v jones's Avatar
do you still have photo can re-load?
NightCat
11
04-18-2009 03:05 PM
00ekcoupe
13
08-27-2005 10:52 AM
spicoli
11
06-09-2004 08:59 PM
n3v3tz
02-05-2004 12:07 PM
Berwyn74
11-17-2003 10:21 AM
Quick Reply: driver side window falls off track wtf
