o.e.m 36mm 4 lug hubs?
Does anyone know if there is a 4 lug 36mm hub i can buy from the dealer that will fit a 99 civic si, so that i can use straight rsx axles for a k series swap? I know the 96-97 spec jdm itrs were 4 lug, does anyone have part numbers? Also are the 97-98 us itrs 4 lug? if so does anyone know the part numbers to the hubs ?>
Re: o.e.m 36mm 4 lug hubs? (jrbreaker85)
you can use the 92+ prelude/accord hubs. they are 4x114.3 36mm hubs. but, i don't know if you can actually press them in to the civic assembly.
Seagull Management
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jrbreaker85 »</TD></TR><TR><TD CLASS="quote">what about the 97 spec itr hubs?</TD></TR></TABLE>
32mm I believe, only the '98+ JDM ITRs are 36mm from what i've heard.
Re: o.e.m 36mm 4 lug hubs? (TurboEK9Coupe)
they are 36
I need to know if there are 4x100 36mm hubs i can use for a k20 swap. i know circuit worxs makes them, but im looking for a cheaper alternative. there has to be somthing out there.
THANKS FOR THE REPLIES GUYS KEEP THEM COMING!
boostedcivicsir
03-27-2007 05:18 PM
