gas gauges dooesnt move it just stays in one spot at all times
Old 10-22-2008, 05:34 AM
JDMfan77's Avatar
Default gas gauges dooesnt move it just stays in one spot at all times
anyone have any ideas on how to fix this my gas guage stays in one spot doesnt move at all all my other gauges work fine this one doesnt move
Old 10-22-2008, 07:41 AM
JDMekBoosted's Avatar
Default Re: gas gauges dooesnt move it just stays in one spot at all times (JDMfan77)
did you ever mess with the needle? or it may be your sending unit or the wiring it could be a few things. see if one of your friends could swap clusters for like 5 mins and see if it works. anyone else i no there could be other things i just listed a few.
Old 10-22-2008, 07:43 AM
TeamRPM_ZC's Avatar
your sending unit is busted
Old 10-22-2008, 07:44 AM
oh and the only reason i said ask someone to put their cluster in knowing their gas works it wouldnt cost you anything and you can go from there.
Old 10-22-2008, 08:03 AM
Mrmatt3465's Avatar
Default Re: gas gauges dooesnt move it just stays in one spot at all times (JDMekBoosted)
Check the sending unit sensor. I don't believe you have to drop the tank to look at it. I think you can get to it from your back seat. There may be build up on the sensor or the "fingers" may be broken
Old 10-23-2008, 07:59 AM
JDMfan77's Avatar
Default Re: gas gauges dooesnt move it just stays in one spot at all times (Mrmatt3465)
how would i get to it man?
Old 10-23-2008, 08:03 AM
TravisCadello's Avatar
do they mess up when you move them with your hand?
Mine was a wire behind the cluster that got cut somehow by the dashs sharp edges when i was moving my gauge cluster.
Old 10-23-2008, 08:52 AM
DTA-Zombie's Avatar
just had the same thing - my original 107k cluster died at least that part - swapped in a different cluster with no problems
runtohell121
16
02-04-2010 04:11 PM
tekniq
01-18-2009 01:17 AM
hypnotize
08-30-2004 08:27 AM
blacksoul
06-09-2002 10:05 AM
accordfreak
01-24-2002 12:44 PM
Quick Reply: gas gauges dooesnt move it just stays in one spot at all times
