~~~gas tank pressure sensor question~~~
Could anyone tells me if this is true? I found this from another Honda forum...
"As far as i know, there is no easy fix for the tank pressure sensor. There was some kind of Katman write-up a while back but I don't have the link. I think you can probably short the oil pressure switch wires together to complete the circuit for the sensor. If you don't find a way to fix that, you will have no VTEC."
I do have the gas tank pressure sensor problem, because my 4 doors don't have that sensor, and i'm running a d16y8 motor with P2P ecu...which causing the CEL always ON.
any kinda answers are welcome. thanks guys
Re: ~~~gas tank pressure sensor question~~~ (baller status)
I think that guy means the fuel pressure sensor in this case.
So, let's say if the fuel tank pressure sensor really have a problem, there is no signal to the ecu, does that affect the VTEC to run appropriately?
baruba
05-24-2014 01:53 PM
