Just swaped. no fuel? bad ECU?
Just swapped a '99 LS motor into a '99 coupe. We used a ODB2b to ODB2a jumper harness.
Trouble shooting: i kept blowing the FI E/M Fuse under the hood so i unpluged almost the hole harness and as soon as i turn the key to ON fuse blows still. Finally i plug in my friends GSR(chipped p28) ecu and it dosnt blow. I pluged the harness back in and still didnt blow
PROBLEM: if i use my p75 it will blow the fuse every time i turn the key. Is my ECU bad? Also even if i use either my p75 or my friends GSR(chipped p28) ECU the fuel pump wont prime. I checked all my fuses under my dash also, i don't think my fuel pump is bad because it worked rite before the swap took place. car cranks fine but im not getting fuel and im running out of options.
any help would be great
EDIT: I searched everything i think it could possibly be
Modified by mattyv at 2:03 PM 10/23/2008
Modified by mattyv at 8:05 PM 10/23/2008
HELLO,GOOD MORNIN'
Re: Just swaped. no fuel? bad ECU? (mattyv)
I've done a swap like this and where the ecu is there is another green harness plug make sure it's plugged in. My first swap i forgot t plug it in (which i didnt even have to unplug it) and the car didnt start or 2 days until i realized it.
ck your main relay.
and something is grounding out, was the ecu ck'd before you did the swap?
ck your main relay.
Plugged in my friends b16 ECU and it started rite up So either my ECU(p75) or jumper harness is bad.. also i only throw crank positioning sensor code. I thought there would be more issues running a ODB2b ECU and harness with a ODB2a motor. although my car redlined at 3k with b16 ECU and redlined at 3500 using a odb2b to odb1 jumper and stock odb1 LS ECU. not sure what to do about that
yea. i was gonna contact Hmotors.
also i hear theres an immobilizer on the p75 ECU (LS) '99 should the jumper bypass that or will i have to get that burned?
Seagull Management
Re: (mattyv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattyv »</TD></TR><TR><TD CLASS="quote">need to know if the p75 LS ECU has an immobilizer. that might cause it?</TD></TR></TABLE>
'99 - '01 USDM Integra ECUs have an immobilizer in them.
HELLO,GOOD MORNIN'
Re: (mattyv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattyv »</TD></TR><TR><TD CLASS="quote"> TTT for answers</TD></TR></TABLE>
sorry i was quit busy. lost a love-one.
yes as stated.
yes as stated.
Seagull Management
Re: (mattyv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattyv »</TD></TR><TR><TD CLASS="quote">we established that. need to know if the p75 LS ECU has an immobilizer. that might cause it?</TD></TR></TABLE>
If its USDM yes, if its JDM no. If its USDM the car will not start
fabe85
53
06-07-2011 11:40 AM
importeclipsegst
16
11-03-2006 01:50 PM
