iac valve questions
Old 05-07-2010, 03:01 PM
mudchuck's Avatar
Default iac valve questions
New here soooo, Hi !!! I just bought a 99 civic that had the valve replaced already. Problem is that it didn't fix the problem of the engine surging at idle.
Any ideas on what to check next?
thanks Chuck
Old 05-07-2010, 03:04 PM
LambertdelSol's Avatar
Default Re: iac valve questions
I'm having the same problems with my d16z6 in my del Sol. I think my IAVC is bad, but I did clean the fast idle thermo-valve (FITV) and it was dirty. It's located on the bottom of your throttle body. Try cleaning that with brake cleaner and see if that helps.
Here is a link to show how it's done:
http://www.team-integra.net/forum/di...g+Common+Topic
Old 05-08-2010, 03:39 AM
mudchuck's Avatar
I do have a check engine light also. The code is P1509. Assuming the new valve is good then what and why would the wiring coming to it fail?
OK, I bought a manual. Did all the tests and everything checks out good. The book then says to have PCM checked out by dealer.
Chuck
MrExclusive
02-17-2010 08:41 AM
d_EG COUPE
19
06-21-2009 07:02 PM
civicb16eg
07-18-2007 06:15 PM
ramoer
18
03-31-2006 07:51 AM
Soccerking3000
08-05-2004 05:57 PM
Quick Reply: iac valve questions
