95 Civic Ex B18b Swap...Running Hot
Well ive got a 95 civic ex with a b18b1 swap in it just droped in 2 days ago..And i have the Fan Wired to when the key is on its running...Ihave Fan Switch Hooked up...I Bled The whole system...And it still over heated?...It sounds a little out of time Could that be issue...After i over heated i took thermostat out and filled system up an bled again...Now it says it runs under normal...But you touch anywhere on the motor its fire hot...i kno how hot a car is spsosed to get but its crazy hot....The whole motor is stock execpt...JG Adjustable Camgears...Msd Blaster 2 Coil...High Flow Cat...2.5" Intake...Act 3900 Xtreme Pressure Plate...Quaife LSD...H22 340CC injectors....But its all stock its not detianation or nothin.....???????
So what can this problem be? Thanks Guys
rasta420
11
11-20-2002 08:05 AM
biggtopscott
08-21-2001 02:14 PM
