Timing Belt Cover
Timing Belt Cover
I have a 1995 Honda Civic CX and I am trying to figure out, how do you remove the Upper back timing cover (the one behind the cam gear). Do you have to remove the head and then remove the one bolt to slide it off or is there more to it then that?
I pulled off the timing valve cover and the timing belt felt a little loose between the two cam gear
Sinner
03-24-2008 08:43 AM
