94 civic dx starting issue
Old 05-02-2011, 05:17 PM
00323's Avatar
Default 94 civic dx starting issue
So my civic wont start anymore after last week.. Didnt do anything.. So it cranks and thats it.. I can hear the fuel pump so its. Its not thats..checked my grounds/fuses/wires all check out..tried 2 main relays both same thing.. Only way i can get it started is by push starting it..any ideas? Distributor maybe?
Old 05-02-2011, 06:46 PM
Former User's Avatar
Default Re: 94 civic dx starting issue
Test the ignition switch -- see FAQs sticky.
Old 05-06-2011, 01:47 PM
00323's Avatar
Ok new ignition switch new main relay still having the same issue... Just cranks and no start..any ideas? The only way it will start is if i push start it
Old 05-06-2011, 01:56 PM
The fuel pump primes when the key is turned from OFF to ON(II), right?
But you can push start the engine, right?
And when the key is in ON(II), the starter turns the engine but it won't start, right?
When cranking the engine in ON(III), have you checked for spark at the plugs and whether the injector spray fuel?
Old 05-06-2011, 02:03 PM
00323's Avatar
But you can push stat the engine, right?
Yea fuel pump primes..
Only start when i push start it
Starter turn but no engine start
No spark.. New dist month ago
Old 05-06-2011, 02:05 PM
Sounds like an ignition switch problem. Test it.
Old 05-06-2011, 02:09 PM
00323's Avatar
How do i test the ignition switch?
Old 05-06-2011, 02:15 PM
You'll find a diagram in the electrical section of the FAQs sticky.
Old 05-06-2011, 02:31 PM
00323's Avatar
Thanks ill try that in a bit
courtham916
04-11-2014 06:57 PM
mibayaua
10-28-2012 11:40 PM
Arthas
09-02-2010 06:42 AM
clewis3
03-28-2010 02:57 PM
taboo948
05-19-2008 07:26 AM
Quick Reply: 94 civic dx starting issue
