92 Civic CX/JDM B16 - fuel injectors not working (solved)
first off for who dont know i have a 92 cx with a jdm b16a the problem that iam having is iam getting fuel to the fuel rail but not to the motor i tried 2 diffrent injectors and still nothing i check the ground wires what should be the fuel psi and how do i check it second question is the fuel pump i know it works i can here it kick on when i turn the key is there anyway to check it to see if it working right
Re: 92 Civic CX/JDM B16 - fuel injectors not working
i think i figured out why my car woln't start i checked everything the fuses the main relay and i even tried diffrent injectors so i was thinking that the ecu was bad but i took it to a friends house and put it in his car and it started up so i tested the wires on the injectors and nothing so iam pretty sure that somewhere the wire to the injectors got ****ed up so iam going to pickup a nother wiring harness tomorrow
well i got the car started and its running fine and not throwing any codes the reason it wouldn't start was my dumb *** forgot to plug on of the caps back on the wires on the driver sider there is a bundle of wires that look like they are caped off but its really a circut thanks for all the help guys
Re: 92 Civic CX/JDM B16 - fuel injectors not working (solved)
Ive got a 92 teg with a b20 and having some what of the same problem, ok so ive had the car for a few days and ran fine up until yesterday, it would start just fine then just crank over, ive got spark, replaced the main relay after finding out my other one was fried, still will just crank over, fuel pump is on a switch and dose work, if I spray starting fluid in it will start and run for a few seconds then die,
I could really use the help as I am new to imports
