DelSol - Removing the plastic pieces that are around roof/back window?
I need to respray the plastic pieces as they have faded from red to grey... They kiggle a bit when you push or pull on them. Was jsut wondering if they pop off or something, have screws that I cant see, or what the deal is.
Would be easier to just spray them and then reinstall them.
Re: DelSol - Removing the plastic pieces that are around roof/back window?
theres a screw holding the light shroud remove then I think there's one screw behind the light and the corners are clipped just pry don't be shy try to jerk so it don't bend and that's it. removed mine to install the wing.
..what wing did you install on a DS that needed you to take out the interior panels?
dopamean
11-19-2008 05:06 PM
hothatch
06-28-2001 01:18 AM
