A/c Checklist
A/c Checklist
Real quick give me a list of things to check when the a/c compressor won't turn on.
Things already checked:
Dashboard switch makes the engine speed change as it tries to kick the compressor on, so the switch prob works
jumped the pressure sensor with a wire, did not turn the compressor on, rules out bad charge or broken sensor
fuses good
I did find that slamming the hood made it come on for about 30 sec. Also, hitting the frame under the hood with a hammer will sometimes do this as well.
Thanks!
fuses good
Thanks!
Re: A/c Checklist
Ok I found the ground wire for the condenser fan and their must be something wrong because it has a charge. It sparked my socket wrench when I went to unscrew it....
Re: A/c Checklist
Also, here is some reading: https://honda-tech.com/forums/showthread.php?t=2900177
Re: A/c Checklist
i didn't bother to post to post the model info as all 1992-2000 civic's air conditioner's are exactly the same.
I'm just going to replace some wiring that looked corroded and loose near the condenser.
Also is there a easy way to jump the sensor that is on top of the compressor to rule it out?
Christopher2222
11-17-2009 05:22 AM
nicholi185
07-25-2007 10:14 AM
