TDC mark on crankshaft pulley..
what color is the tdc mark on the crankshaft pulley on a d16z6?.. is it the white one also what degree should i set the ignition timing..
Re: TDC mark on crankshaft pulley.. (pg_thao)
this doesn't answer your exact question, but on my friend's b20, the white mark is TDC and the red one was 16 degrees (and it had a mark for 14 degrees and 18 degrees). look to see if you see a mark on either side of the white mark. if you don't, its probably TDC then.
USDM 4G VTEC
06-21-2002 10:08 AM
