help with changing rotor!
Old 05-14-2003, 06:17 PM
SIMATIC's Avatar
Default help with changing rotor!
i just bought new front rotors for my 93 civic. I took everything off and then i went to unscrew those 2 little screws that hold the rotor in and they wouldnt move. I tryed WD-40 and using a screwdriver. then i went and bought that special tool that you are supposed to use---> that silver, spring loaded rod that u hit with a hammer and it turns the bit. or maybe i wasnt using that tool right, if you know what im talkin about, that didnt work either. Any one have any ideas on how im supposed to get these screws off??? thanks for any help you can give me
Old 05-14-2003, 06:19 PM
degooser's Avatar
Default Re: help with changing rotor! (SIMATIC)
that thing u bought is an impact happer right?? like you bang it with a hammer and it turns???
If thats what u bought then thats what u should use...
Old 05-14-2003, 06:22 PM
HndaCvcRcr's Avatar
Just keep putting wd-40 or maybe even croil (bolt losener) to try and get it loose. I hate to say it, but kicking it and banging it don't do TOO much. I've been in your position MANY times and it SUCKS. All I can say is have patients!
Good Luck...
Blake
Old 05-14-2003, 06:27 PM
95hbMatt's Avatar
Default Re: help with changing rotor! (HndaCvcRcr)
Impact with a phillips head bit....if you don't have access to an impact gun then drill them out...that's what I did....I broke the bit trying to get them out with an impact so I got my drill and drilled them biyatches out..you don't really need them...your wheels will hold he rotors on....
Old 05-14-2003, 06:29 PM
tonyxcom's Avatar
We have always used an impact screwdriver and it has ALWAYS worked.
When using the impact screwdriver, remember that it can both loosen AND tighten screws. This is determined by which way you turn it before hitting it.
Turn it towards the way you want then hit it a few times.
Old 05-14-2003, 06:31 PM
Boba Connoisseur
SkyeC's Avatar
I've always used a socket with a phillips bit and a ratchet.
Old 05-14-2003, 06:50 PM
B2FiNiTY's Avatar
Default Re: help with changing rotor! (SkyeC)
It might work but you run more risk stripping it.
Old 05-14-2003, 08:19 PM
whoDAT's Avatar
Default Re: help with changing rotor! (B2FiNiTY)
yup, the impact driver has always worked for me. just bang the **** out of it, if it doesn't budge...try wd-40 and let it sit for a while.
Old 05-14-2003, 09:39 PM
I really don't know
A D NOH's Avatar
Default Re: help with changing rotor! (tonyXcom)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tonyXcom &raquo;</TD></TR><TR><TD CLASS="quote">We have always used an impact screwdriver and it has ALWAYS worked.
Turn it towards the way you want then hit it a few times.</TD></TR></TABLE>
Old 05-14-2003, 09:53 PM
Bigphlip's Avatar
I just hit the rotor with a hammer right around the screws to loosen up the threads and kept spraying on the WD-40. It worked for me just took a little time and patience. Good luck.
Old 05-14-2003, 10:28 PM
whoDAT's Avatar
Default Re: (Bigphlip)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bigphlip &raquo;</TD></TR><TR><TD CLASS="quote">I just hit the rotor with a hammer right around the screws to loosen up the threads and kept spraying on the WD-40. It worked for me just took a little time and patience. Good luck.</TD></TR></TABLE>
hmmmm... an impact-driver sounds like a better/more affective/ and safer way to do it.
Old 05-14-2003, 10:47 PM
youngkow's Avatar
Use that tool that you bought. Just make sure its rotating in the direction you want it to, and just smack it with a hammer. Works everytime, like everyone said.
Old 05-15-2003, 06:50 AM
gohandbz8's Avatar
Default Re: help with changing rotor! (youngkow)
just keep trying with the impact driver. If a normal hammer wont cut it, try getting a 4" sledge hammer. It gives a lot more force when you strike at it.
Old 05-15-2003, 08:43 AM
ImportechPerformance's Avatar
Default Re: help with changing rotor! (gohandbz8)
try searching first noobie this happend to me last week!!
its an awsome article if i must say so myself it shows you exactly what i had to do and what no to do....here you go...
it has pics of tools you might need too!!
https://honda-tech.com/zerothread?id=498610
Old 05-15-2003, 09:53 AM
ChiBoy's Avatar
Drill the heads of the screws out WITHOUT touching the rotors. Use a drill bit that is just a little bit smaller than the head of the screw and leave a little material there rather than drilling the rotor.
Find some bolts that fit the jack screw holes that are 90 degrees from the screws. Thread the bolts in evenly and the heads of the screws should pop off or pull through.
Old 05-15-2003, 09:58 AM
TrboInteg's Avatar
I had the same problem. Needless to say, I don't run those screw's anymore. While I was trying to get mine out I ended up stripping the screw. So, I attempted to use that impact screw driver that had been mentioned and I broke the tip on the #2 bit. The others were too small or to big. I thought I was screwed. Then I got the bright idea of using a cut off wheel. I put I nice big slot down the middle and then I was able to use a flat head screw driver to back the screw out.
Old 05-15-2003, 07:17 PM
SIMATIC's Avatar
Default Re: help with changing rotor! (TrboInteg)
thanks for everyones help, if ur ever gona read this again.. i got alot of ideas and that website was helpfull too. im gona try again 2morro
Old 05-16-2003, 01:42 AM
EddieHatchBlack's Avatar
I take a flat head and pound it into the screw, and than chizel it out. I have a bag full of 100 of them in my garage.
Old 05-16-2003, 02:22 AM
katoeh2o's Avatar
i hade the same problem and i bought the same tool as u. The impact drive i bought had a 1/2 drive socket were you change the bit. so i put that on my breakerbar and use the phillips head the fit a it came of like nothing. It's all about leverage.
Kyle905
04-03-2011 02:18 PM
Discontained
10
01-21-2007 04:46 PM
a1320addict
01-17-2006 10:16 PM
sickofitall1113
06-02-2005 12:01 PM
highmilehatch
04-10-2003 02:00 PM
Quick Reply: help with changing rotor!
