Indiglo guages in a 95 civic
I have a 95 civic and a set of indiglo guages and the crappy instructions tell me to hook the power wire for the indiglo guages to the head lights wire, can ne 1 help me with this? i can't find the headlight wire
Re: Indiglo guages in a 95 civic (95civicdx)
you should really hook it up to the parking lights wire, that way any time you turn on your lights, they will be on....the best way to check it, is to get one of those things that you can stab into the wire and check the current...it has a light and lights up when that wire is active (cant remember what its called)...thats what i did...
https://honda-tech.com/zerothread?id=504117
You can download a Helms manual that should tell you where it will be located.
if it is the same as the ek then pop out the dimmer switch and just put the black to black and find out with one is positive by turning on the headlights and puting the wire in there and if they glow you got it right
mitchh29
31
03-30-2013 12:13 PM
jdmej814
Lighting
01-30-2008 02:07 PM
ScuderiaFerrari
24
11-08-2004 07:41 PM
