oil cap breather
oil cap breather
anybody know of a place that sells oil cap breathers for civics? i have way to much pressure and need to get rid of it some way and thought this would be the best way
Re: oil cap breather (Btothe3rdDegree)
Re: (TheRedSkoolingBus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheRedSkoolingBus »</TD></TR><TR><TD CLASS="quote">What the heck is this thing used for?</TD></TR></TABLE>
i have excess pressure in my crank case which i causing my oil pan gasket to blow out so i was looking for a way to releave that pressure
Re: (Btothe3rdDegree)
Just mod your stock cap... drill a hole in it and the glue a fitting on it... Or just drill a hole in it...
Go to a junkyard and get an oil cap and do it to that one... you should be able to drill and tap the plastic for a fitting with out any problem....
But I don't think that's gunna help you vent excess crankcase pressure... a little but not as much as you'd like...
I'd recomend completely removing the pcv valve and just running a hose with a breather off of that... it's the best way you'll relieve pressure in the pan. not the most enviromentally sound idea but... what are you gunna do?
yoffer
05-11-2007 01:35 PM
EK k kay
12-20-2006 12:05 AM
