Questions about SI cluster into EK hatch
I plan on buying a Si cluster guage and puttin it in my ek hatch. When I buy one, what do I have to make sure that I get with the cluster? i.e. clips,screws,wires? Or do I jus unplug my dx cluster and jus plug the Si cluster in? Thanks in advance
Re: Questions about SI cluster into EK hatch (Integra Type R)
Just unplug the old one and plug the new one in. Make sure it still has the clear plastic cover over the front, so the guages don't get damaged though!
When you get the Si cluster, just make sure it has the 2 green plugs in the back. Then just unplug dx cluster, and plug in the Si cluster. It's really that easy.
Re: Questions about SI cluster into EK hatch (slvrcivic97)
the only tool needed is a screwdriver. Take off the bezel by unscrewing the 2 screws at the top of it. but when removing it be sure not to break the clips that hold the bottom in. Then you will see the cluster sitting there help in by 4 screws. Take those out and grab your cluster unplug the connectors on the back and throw your dx cluster aside, and put it all back together with the si cluster.
