new valve cover + old valve cover gasket???
I am putting a new valve cover on my motor, and i am using the old valve cover gaskets. Should i use gasket sealer in there too to prevent leaks? If so , where should i apply it, if not all around?
jus f0 dekarayshunZ
Re: new valve cover + old valve cover gasket??? (sick hatchem)
ive reused my valve cover gasket about 3 times ...i would reccomend a new one but i didnt have any problems reusing mine
Re: new valve cover + old valve cover gasket??? (ciRcuitSi y0!)
It depends on how beat up your old gasket is.
Regardless, use some Hondabond on the corners and by the cam humps.
Re: new valve cover + old valve cover gasket??? (delsolguy)
the valve cover gaskets are not a traditional "gasket" they're more of a seal. Just make sure both surfaces are clean and the "gasket" is not beat up or torn etc...
It can be reused, and if you replace it everytime you pop off the valve cover, you either
A. buy into too much bs
B. have more money than brains
C. both a & b
C. both a & b
Shaguar47
05-28-2007 08:47 AM
