High Flow Cat
High Flow Cat
where can i buy a bolt on high flow cat for a 1992-1995 dx hatch.
i just installed my new catback exhaust and had to run a test pipe because the old bolts rusted into the cat.
the car sounds good but will not pass emissions with the test pipe.
where can i buy one? and are they worth the money? any power?
will it add any sound?
Re: High Flow Cat (DxHatchback)
i bought my old one (carsound high flow 2.5 cat with adjustable gasket) from http://www.testpipe.com it was for my 94 si hatch with a b16a sir2 equiped with a jdm 4-1 itr header. there was a big difference in power and sound. i say buy it and its not that much, got mines for about 100 shipped new
http://www.summitracing.com
http://www.nopi.com
both have bolt-in hi-flow cats for civics... and both sites should be up.
EDIT:
here's a direct link summits cat...
http://store.summitracing.com/...D4178
good luck
Modified by mathusala at 4:40 PM 10/9/2003
http://www.nopi.com
EDIT:
good luck
Ive called summit for that one...it doesnt fit all hondas (as you might think)
I dont remember which ones exactly...i just remember no sols or ek coupes/sedans
Re: (mathusala)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mathusala »</TD></TR><TR><TD CLASS="quote">i dont know bout the ek, it does fit an eg (and sols). i think they're all the same - at least through 1998... anyone know for sure?
EDIT: ymmv</TD></TR></TABLE>
Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">
Dude...I called them...Im repeating what they said</TD></TR></TABLE>
whatever... I've used the summit one on a '93 eg coupe and a '95 sol vtec (an eg2) but your phone call info is why I gave the 'milage may vary' edit. I still think they're all the same through '98. If the dealer doesn't know wht it fits then I wouldn't buy it either.
Re: High Flow Cat (JV)
ahhh i need a direct fit
i dont like my exhaust shop and dont want to go to them for flanges<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JV »</TD></TR><TR><TD CLASS="quote"> http://www.heeltoeauto.com/mar...x.htm </TD></TR></TABLE>
Email Marcus and see what he can do for you.
http://heeltoeauto.com/contact.htm
You should put a heatshield on around the test pipe so it looks like its the heatshield for the cat. Most inspection places will just see the heatshield and assume you have a cat. If you still have it or one that will fit you should throw it on there to see if it passes.
Re: High Flow Cat (j3tta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by j3tta »</TD></TR><TR><TD CLASS="quote">You should put a heatshield on around the test pipe so it looks like its the heatshield for the cat. Most inspection places will just see the heatshield and assume you have a cat. If you still have it or one that will fit you should throw it on there to see if it passes.</TD></TR></TABLE>
he still wouldnt pass emissions
Re: (citrusdrop)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by citrusdrop »</TD></TR><TR><TD CLASS="quote">would a stock GSR be the same size as a civc?</TD></TR></TABLE>
stock gsr cat is not the same as the civic. the gsr cats are longer. evidence? compare the header of a gsr vs. an ls, b16a.
civic/delsol 92-95 are all the same. my buddy with a 93 civic dx has the same cat as my 95 delsol. the models that have the cat near the engine bay (VX) are of course different.
Modified by DenMatic at 9:46 AM 10/13/2003
