anyone know the part number for the del sol vtec A/C bracket, 99-00 SI driver side mount, and 99-00
need to know part # for del sol vtec A/C bracket, 99-00 SI driver side mount, and 99-00 SI rear mount. hoping to order them from hparts.com or if anyone knows the cheapest place to order then please list.
need them so i can do a 98 gsr swap in my ek. thanks
Re: anyone know the part number for the del sol vtec A/C bracket, 99-00 SI driver side mount, and 99
thanks..
now does anyone know the part # to the 99-00 si driver side mount needed for the swap (b-series into 99-00 coupe ex)
Risky Business
just use http://www.hondaautomotiveparts.com you dont need part numbers...you pick numbers off a drawing and add them to your basket
Just to let you know the 99-01 CRV a\c bracket works also and is a little easier to find.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jDmDxTuRd »</TD></TR><TR><TD CLASS="quote">Just to let you know the 99-01 CRV a\c bracket works also and is a little easier to find. </TD></TR></TABLE>
Really? Wonder if it is any cheaper..I will be having to get one soon too...
okay, still dont know which one it is...(looking for 99-00 si driver side mount needed for gsr swap into 00 coupe ex)
is it number 4 or 5????
link is here http://www.hondaautomotivepart...84%29
or pix is here...
or pix is here...
It's nunber 1 in the pic, number 4 is the driver side mount.
-Jeff C.
-Jeff C.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jcda6 »</TD></TR><TR><TD CLASS="quote">It's nunber 1 in the pic, number 4 is the driver side mount.
-Jeff C.</TD></TR></TABLE>
are you guys positive on this...
is #4 the driver side mount i need for the swap?
Re: (pennies_hatchie)
Here is what you need:
2000 Civic Si
you need number 7 and possibly 10. You need 10 if your swap does not come w/ a front tranny mount(any b-series will do). You don't need 4 unless your stock mount is in bad shape.
http://www.hondaautomotivepart...82%29
In this picture you need number 8.
96 Del Sol Vtec
http://www.hondaautomotivepart...81%29
You need number 1. I think you can get the ac mount from any del sol vtec. I you don't have ac or are removing it, any b-series mount will do. You only need a del sol vtec P54 ac bracket if you want to maintain ac.
The reason I am not 100% about the ac bracket is because I used a jdm itr aluminum ac bracket which requires quite a bit of tapping holes and cutting extra metal. Oh and if your ac bracket pulley does not look like this...
http://www.hondaautomotivepart...EC%29 with parts 15, 16, 17, 20, 21, 22, & 23; you will need those with your bracket
2000 Civic Si
96 Del Sol Vtec
Re: (96BlackHB)
bump, im confused..
what is the driver side mount that everyone is talking about that i need to do the swap?????????
is it #8 in http://www.hondaautomotivepart...82%29
or is it #4 in http://www.hondaautomotivepart...84%29
need confirmation asap
You need 8, you have 4. You can re use your stock mount and the bracket that bolts to the mount(included in number 4). Check out Trey's site:
http://www.phear7imports.net/s...6gen/
You can click on the underlined words in the mounts section and check out the pictures. This site has all the info you need to do a b-series swap in an EK.
If you need a new AC bracket, PM me, I got a few left I need to get rid of
ANGELIQUE
03-15-2005 12:25 PM
