B18b swap
B18b swap
I have a 96 honda civic hatchback cx its obd2 and the motor im going to be putting in is a b18b which is going to be a obd2 motor and i was wondering can i use my same wiring harness and ecu or do i have to use an integera obd2 wiring harness and for who ever done this swap it would help with some good tips thanks.
Re: B18b swap (GeekinEK)
you can use the wiring harness that you have off your civic motor, but you will need the ecu from an LS. and if you want obd1 you will need the jumper harness too. good luck on the swap its really easy!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GeekinEK »</TD></TR><TR><TD CLASS="quote">I have a 96 honda civic hatchback cx its obd2 and the motor im going to be putting in is a b18b which is going to be a obd2 motor and i was wondering can i use my same wiring harness and ecu or do i have to use an integera obd2 wiring harness and for who ever done this swap it would help with some good tips thanks.</TD></TR></TABLE>
You will be able to utilize your current civic wiring harness. However the question lies in what year b18b ecu will you be using? There are two versions of OBD2. There is OBD2a(96-98) and OBD2b(99-01) Knowing that your car is a 96 honda civic...you are OBD2a. If your b18b ecu came from a 96-98 integra then the ECU will plug right up to your harness...but if you have a 99-01 integra ecu then you'll need an obd2a-->obd2b conversoin harness for it to be plug and play. However be aware that the 00-01 integra ECU comes with the immobilzer which will make it more complicated. Easiest route for you is to make sure you have a 96-98 b18b ecu so that it would be plug and play. Good Luck!!
Khoi
Khoi
Re: B18b swap (Sohc Driver)
and if your using your existing wiring harness, there are a few plugs that you have to cut and splice and extend. And some plugs you have to change actual plug.
Re: B18b swap (b20_EK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20_EK »</TD></TR><TR><TD CLASS="quote">and if your using your existing wiring harness, there are a few plugs that you have to cut and splice and extend. And some plugs you have to change actual plug. </TD></TR></TABLE>
huh?? Under what case would you have to do any of this? My swap was straight plug and play.
Khoi
Khoi
Re: (XxLuckyLisaxX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XxLuckyLisaxX »</TD></TR><TR><TD CLASS="quote">do u have to buy b-series mounts to put b18b in a 92 hatch??? i said yes but friend says no, whos right?</TD></TR></TABLE>
You are.
You'll need the upper "timing belt" mount, lower "AC" mount, front lower tranny mount, and the rear mount bracket (metal mount on the back of the motor) from the LS.
You are.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sohc Driver »</TD></TR><TR><TD CLASS="quote">
Khoi</TD></TR></TABLE>
well, reading from your signature, Im guessing you used the EX harness. The DX harness is different.
j4s0n1337
19
07-21-2019 06:47 PM
Cristorey34
08-06-2005 07:36 AM
