b18a1 in my ej6
b18a1 in my ej6
wats up h-t, later this week i will be buying a 93 b18a1 complete swap with about 80k from a buddy and ive done many searches to answer a couple of questions i have about this swap into my car but all the info i get basically still leaves me confused, so here it goes:
-since the ls motor comes with a cable tranny, will i be able to swap it out for a hydro tranny?
-will it bolt right up? will i need misc parts to make it work?
-mounts, will i need both the driver side and rear mounts from a 99-00 si?
TIA
TIA
Former Moderator
Re: b18a1 in my ej6 (SlepT ej6)
You can bolt any hydro b series tranny to that B18A1.
Treat the mounts as if you were swapping in any other B-series engine.
I know that there is mounting info for the 1996-2000 civics in the stickied FAQ topic up top in this forum.
If you had an Eg I could give you a 100% answer, but since I'm not the EK guy you can find the definate answer up top.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlepT ej6 »</TD></TR><TR><TD CLASS="quote">wats up h-t, later this week i will be buying a 93 b18a1 complete swap with about 80k from a buddy and ive done many searches to answer a couple of questions i have about this swap into my car but all the info i get basically still leaves me confused, so here it goes:
TIA </TD></TR></TABLE>
you will need all new mounts because your going from a d-series to a b-series.
you can switch any B-SERIES trannies, in other words dont go putting your d16 or d17 tranny on your b18.
other than that it should all pretty much bolt up
Re: b18a1 in my ej6 (99EKhatch)
d onto b-- that would be big time , but are your sure i must change all my mounts, thats something i have researched alot and im pretty sure its only those two mounts i must change b/c supposedly the other d series mounts will work...... (will defintely be checking faq)
TIA
TIA
another question that leaves me confused is whether a jdm 4-1 itr header will bolt up to the b18a1?
also wat are some good sites to find a b16 or itr tranny?
thanx guys!
thanx guys!
you will have to change 3 mount one right next to the time belt one right ontop of the tranny and then the tranny tourqe mount one, and i think you replace this on with that from an 00si
