Hello. Help again :)
Well I got my new starter installed and wired up ready to go and still...when I turn the key over I can hear the solenoid clicking but no turn over. Hell it doesnt even try. I checked all my MSD connections and they seem good. The battery also seems perfect. The only thing suspicious is a noise right behind the dash area. I have the dash out of the car so when I turn the key I hear this solenoid sounding or relay sounding click towards the fuse box. Any suggestions on why it wont start. Let me remind you I went down one night and the dang thing just wouldnt start..made a rapid clicking sound..checked the battery and replaced the starter...now what?
Re: Hello. Help again :) (EG6-EF9)
All the grounds that I know of are hooked up. The only one I would question is the ground that comes out of the main harness..does it got to the starter or the block? I thought it was the starter cuase the starter has a bolt on top the motor housing. What fuses would you check to prevent the car from starting? and what about the ignition switch?
nursebryan
08-20-2014 02:54 AM
