D series...ARP head stud washers?????
Munkyw3rkz.webs.com
1 Post
Ok myself and Hella_JDM were changing out the headgasket and installing the ARP head studs on a Y8 block and noticed there is a 2/3 of an inch gap...we searched and saw a few post of the same problems.....how many others have had this happen?
Also would it be a bad idea to place washers to fill inthe gap?
OG triple OG
Re: D series...ARP head stud washers????? (SnoFlake EG)
those pieces of **** , they "JUST" came out with y8 studs , i have the box that just says d16 on it....but these are now the d16z studs.
im gonna go tomorow and get washers to make up for the extra room , hope it works....
Munkyw3rkz.webs.com
1 Post
Re: D series...ARP head stud washers????? (Hella_JDM)
Yo Mark check to see if you can find some at work that we can use...check with airframes.....
Did you compare the stud lengths to the stock bolts?
Maybe need to run a tap down into the block?
Munkyw3rkz.webs.com
1 Post
Re: D series...ARP head stud washers????? (Marauder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Marauder »</TD></TR><TR><TD CLASS="quote">Did you compare the stud lengths to the stock bolts?
Maybe need to run a tap down into the block?</TD></TR></TABLE>
i dont think so...the thing is ARP just came out with another set. so theres one for the Y8 block and one for Z6...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM »</TD></TR><TR><TD CLASS="quote">those pieces of **** , they "JUST" came out with y8 studs , i have the box that just says d16 on it....but these are now the d16z studs.
im gonna go tomorow and get washers to make up for the extra room , hope it works....</TD></TR></TABLE>
They didn't JUST come out with the Y8 head studs. I bought my D16Y ARP head studs last March.
Re: D series...ARP head stud washers????? (RyanCivic2000)
while putting head studs on my motor (d16y7 block, d16z6 head) i bought the d16 set first. they were too long i believe. i couldnt return them b/c they were scuffed and what not.... i purchased the d16z set and 2 of them were too short. what kind of washers are you guys gonna use?? if its similar to the arp's i say go for it if u cant get the proper set.
i got a set of d16's for sale on my site...check the part# to be sure.
http://www.nerdsports.net/remodel/misc/forsale.htm
CyberC1ren
12-02-2013 10:30 AM
sundownz
02-17-2007 08:27 AM
gubo22
10-17-2006 03:24 PM
