Help me label this pic please.
First of all, the engine bay pic belongs to a guy named "JDMlifestyle." I hope you don't mind me using this pic (it was the first engine bay pic i found when i searched of a b16). If you don't want it shown, i will take it off.
Anyway, i'm running a few codes, can you help me label where the sensors are please.
TPS - throttle position sensor
IAC (EACV) - idle air control valve
20 Electrical load detector
23 Knock sensor
Can somebody label this pic with arrows of some sort and explain to me where these sensos/valve/detector are located...thanks. I am throwing all 4 of these codes.
23 Knock sensor
the tps is located on the top of the throttle body!
the knock sensor is on the back of the block under the intake manifold!
not sure about the rest!
Re: Help me label this pic please. (1.8 HB)
Ask the user TeamNextGenChris for the website with the Helms downloads. All you will ever need to know is in there. If you don't have Adobe Reader or whatever its called you might want to download the latest version....
Re: Help me label this pic please. (DelSlowTurbo)
The ELD is inside the engine bay fuse box. It is not a replaceable part. The knock sensor is on the back side of the block, by the oil filter.
