Master Cylinder of an EG SI w/ ABS to a DX w/o ABS????
Will a brake master cylinder off an SI HB with ABS work onto a DX without ABS? Its obvious that the master cylinder is bigger, but will I have problems?
Solbros Owns Me
Re: Master Cylinder of an EG SI w/ ABS to a DX w/o ABS???? (LSVTECoupe)
one of the fittings for the brake lines is slightly bigger. You can just reflare with a bigger fitting and it will work fine
