OK, what sohc tranny for a turbo...
I was wondering what sohc tranny I should run on a 96 DX/ h/b. I heard that a dx tranny does great because the gears are longer. Would an ex, si tranny be better. Also I'll be runnin' the stock sohc "non vtec" motor, THANKS
Re: OK, what sohc tranny for a turbo... (Pete_SI)
if u r running an sohc vtec turbo use non vtec tranny! but if u are using non vtec motor run vtec tranny ! seems to work the best !
Re: OK, what sohc tranny for a turbo... (rw92civic)
I don't understand this......if you make your peak power at a high rpm, wouldn't you want a tranny that keeps the revs in that range, regardless if you are turbo or NA?
Re: OK, what sohc tranny for a turbo... (Spade)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spade »</TD></TR><TR><TD CLASS="quote">EX tranny 96-00</TD></TR></TABLE>
that's definately what you want. don't listen to these idiots that tell you to use longer gears. i believe someone over at turbod16 was using the worthless dx tranny and running low 15s. he switched to the ex, and was getting high 13s. you want the 96-00 because it has the stronger steel shift forks, instead of the aluminum ones in the 92-95.
Re: OK, what sohc tranny for a turbo... (jwn7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jwn7 »</TD></TR><TR><TD CLASS="quote">
that's definately what you want. don't listen to these idiots that tell you to use longer gears. i believe someone over at turbod16 was using the worthless dx tranny and running low 15s. he switched to the ex, and was getting high 13s. you want the 96-00 because it has the stronger steel shift forks, instead of the aluminum ones in the 92-95. </TD></TR></TABLE>
yes. and if you wanna go all out- get an lsd for that biatch
Now my next question, if I was to purchase a 96-00 ex tranny how much would one cost used.
Re: OK, what sohc tranny for a turbo... (Archidictus)
i've been hunting one in good condition for awhile now. haven't really found a decent one for cheaper than 400 bucks. i had one with 17k for $200 but it slipped through my fingers . if you find one and don't want it, let me know - i'll do the same for you .
Thanks Guys.... My last question, if I was to have a non-vtec motor with an ex (96-00) tranny how much would that save me on my 1/4 mile ( no exact figure) just a ballpark... THANKS
MiG-21 superfan
Re: OK, what sohc tranny for a turbo... (jdmjeff)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmjeff »</TD></TR><TR><TD CLASS="quote">Thanks Guys.... My last question, if I was to have a non-vtec motor with an ex (96-00) tranny how much would that save me on my 1/4 mile ( no exact figure) just a ballpark... THANKS </TD></TR></TABLE>
depends on mods, but the ideal improvement w/ basic bolt-ons seems to be about half a second or so.
the 96-00 EX trans is the best trans for any sohc build, NA, turbo....anything. Second best would be a 92-95 EX or Si trans, unless you are trying for a top-speed record, in that case the cx/dx EK hatch trans and its 3.72 FD would be perfect
bonta-kun
46
03-11-2005 08:24 AM
ROYGUZMAN97
07-04-2004 05:10 PM
