Vehicle speed sensor problem!
yesterday I took a vss to a friends house to test it in his 98 civic to see if it was was working because I couldnt get it to work in my car with my sir cluster. I took his out, then tested mine and it didnt work but thats not my problem.
When I went put his back in I put it in correctly plugged up the connector and reset the ecu. But for some reason his car is not getting a signal and is flashing a a check engine light. Anyone that might have any clue how to fix it let me know
The fuse is still good, the sensor is getting power and has a good ground. everything worked fine before but now it just wont work.
thanks in advance
thanks in advance
Re: Vehicle speed sensor problem! (90civichbsi)
Stupid question for you:
How do you know the sensor is not sending a signal?
Do you know what code you are pulling (CEL)?
fs
fs
AHHH i finally figured it out, the positive pin on the vss connector was severely corroded, i cleaned it out b4 and it didnt work... but i tested the vss in a different car and it worked..
now after i decided to solder in a new 3P connector it works like a charm.
Re: Vehicle speed sensor problem! (civic_rice)
Perfect example of what to do when you get a CEL code and tackle a diagnosis procedure on your car. Always look at connections, pins, wires first... Usually that is the problem... Much cheaper....
fs
fs
ONEhaque
11-04-2008 06:31 PM
speed.freak
06-08-2005 01:40 PM
