GSR Rear swaybar on 99 civic???
Old 03-16-2004, 06:47 PM
gabspeed's Avatar
Default GSR Rear swaybar on 99 civic???
HI i would like to know if it will be a direct bolt on a gsr rear sway bar on a 99 civic coupe? anybody? thanks in advance
Old 03-24-2004, 09:14 AM
gabebauman's Avatar
Default Re: GSR Rear swaybar on 99 civic??? (gabspeed)
Read This First
http://www.clubcivic.com/board...13651
Old 03-27-2004, 03:13 PM
gabspeed's Avatar
Default Re: GSR Rear swaybar on 99 civic??? (gabebauman)
now from bellow information.. why not just open a new whole to the rear lower controlarms of the civic??? and use the same GSR or Typr end links??anybody had thought of that?
"As for the GSR bar, I need to try it myself to be sure. But the GSR endlinks don't have a ball pivot like the Si's do. So it the width doesn't match (which the GSR doesn't match the 6th gen civic EX) then it won't fit; short by about 1/2" on both sides. But, using Si endlinks, the ball joint will turn to allow you to reach.
The GSR mounts don't match so you need Si mounts, but with the GSR 14mm bushings. Hold on, lemme check... "
View Public Profile
Send a private message to chimchim
Send email to chimchim
Find More Posts by chimchim
Add chimchim to Your Buddy List
01-20-2004, 07:46 PM #5
chimchim
iVTEC, do you?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gabebauman &raquo;</TD></TR><TR><TD CLASS="quote">Read This First
http://www.clubcivic.com/board...13651</TD></TR></TABLE>
Ukrainamese
Suspension & Brakes
21
12-08-2013 08:32 AM
Solscud007
12-09-2004 03:48 PM
dohcdelsol
06-01-2004 06:24 PM
deviant94ex
03-26-2002 07:21 AM
Pressurized
11-28-2001 03:09 PM
Quick Reply: GSR Rear swaybar on 99 civic???
