d16z6 crank/block girddle question?
Durring the rebuild of my engine I found out that my crank and girddle is totally F%&^%$ up when the crank moved and grind up against the thrust washer along with the girddle. I found a crank/block girddle on ebay but its from a 91 si engine..I know that crank works on d16z6 blocks but not sure about the girddle, anyone with info on this? let me know thanks.
Re: d16z6 crank/block girddle question? (D-booster)
The girdle should fit, but you have to get it align honed, which can be quite pricey. You might be better off to just buy the whole block.
