help with koni yellows
Re: help with koni yellows (808b18c1boosted)
Yes they will with a slight modification. On the rear where the strut mounts to the Lower Control Arm you will have to add spacers. The GSR LCA's are about 1/2 inch narrower than the 96-2000 civic LCA's. You can use washers as spacers on both sides of the LCA. Hope this helps.
