Could a bigger tb make your car bog?
i just started noticing this after my TB install. i upgraded from a stock d16z6 to a b18b TB. Now every once in awhile (usually after i shut the car off and back on) the car bogs, and when i start off it drops to a real low RPM then sometimes stalls. Well i tried the TPS sensor test (disconnect it and run it off, if it runs good thats the prob (supositely) ) well i did that and it ran good! so i changed the TPS and after a few drives it did it again?! im not sure what to do? im beginning to think its the TB but i hear everyone else does it and i never heard any problems. im just confused as hell now
Re: Could a bigger tb make your car bog? (DjFreeze)
1. did you recalibrate the tps (using a multimeter) after swapping it?
2. did you use the tb gasket that matches the tb or did you keep your old one?
SLowCrx
04-08-2004 03:04 PM
