HELP!!!! fuel rail bolts broke
I just got done changing the gasket and i didnt put any pressure at all on the bolts. the first bolt is broken off inside the manifold. the 2nd bolt is stuck out a lil bit. and the 3rd bolt broke off in the manifold. how in the hell do i get these out? the bolts were not even 1/2 way tight
Re: HELP!!!! fuel rail bolts broke (JDMlifestyle)
Get a small drill bit and drill a hole in the middle of the bolt. Then use an "Extraction Kit." Or you can buy a new Intake Manifold and new Fuel Rail Bolts.
TSPeed Factory
Re: (JDMlifestyle)
shouldn't they come with studs in the first place instead of bolts? well i did the same exact thing as you. i just vice gripped the studs and screwed it out and replaced it with new studs.
