4040 Prop valve question
I have a integra rear disc swap on my eg and i want to install a 4040 prop valve.
I know that the 90-93 integra and 94+RS integra valves will work but will i have to bend the lines to make the valve fit? Is the Eg Si valve the only one that will work without having to bend lines?
Re: 4040 Prop valve question (FerioVtec94)
wait im confused, if you have the MC and BB from a teg then no you don't have to rebend the lines, and you can't use the prop valve of any 90-93 teg it has to be one without abs. this is as far as i know from the info that b18c5_eh2 has posted and the info the guy at the junk yard told me. if you use the one from a civic SI it has ABS i think, but im not sure. if it does you can't use it if it didn't then you can
<-------wondering what the 40-40 came on?
Im knee deep in these damn 30-30 prop valves.
They are all from 4 wheel disc brake cars, but you
guys are set on the 40-40's .
FOR A FACT: an RS proportioning valve WILL work on the EG, WITHOUT BENDING ANY LINES. i just did this on my car last week. i posted a how to if you want pics.
