DIY/How to: Del Sol Seats into an EK - Honda-Tech - Honda Forum Discussion
Old 04-08-2004, 11:44 AM
Ricey McRicerton's Avatar
Default DIY/How to: Del Sol Seats into an EK
Well, I've heard lots of rumors and whatnot about what you need to do to get the Sols into an EK, so I picked some up and did it.
First of all you need to pull your EK seats out of your car. It's 4 bolts and a connector (once you have the seatbelt connector out, don't turn the car on, or your SRS light will come on!)
After the seats are out, start breaking the seats down. You need to remove the covers over the brackets. Once you have that off, you need to remove the reclining handles and then start removing the brackets from the seats.
I suggest doing these one seat at a time, as to not get the sliders/rails confused with each other.
These are what you need to remove (these are from the Sol Seats):
This is what your stock EK seats should be left as (forgive the indention in it, they've been sitting in a box since I swapped them out):
And then put the EK rails/sliders onto the Del Sol seats. They bolt right up using all of the original hardware.
Once you have a seat/bracket assembly put back together go put it back into the car and end up with this:
These are the absolute BEST seats I've ever sat in. I would own these over a Sparco or Recaro seat any day. Best part is, they're cheap!
Ricey McRicerton is offline
Old 04-08-2004, 11:50 AM
deeksmooth's Avatar
Default Re: DIY/How to: Del Sol Seats into an EK (Ricey McRicerton)
nice write up , i have them in my EK too... love them, actually if i'm not mistaken, i'm 90% sure they are manu'ed by recaro. only thing i see left out is how ppl are going to complain about the bolts not lining up just right. i fixed this by starting all the bolts through the rails and into the floor board, then tightened them down in this order;
FRONT OUTSIDE, FRONT INSDIE, REAR OUTSIDE, REAR INSIDE.
deeksmooth is offline
Old 04-08-2004, 11:59 AM
pdiggitydogg's Avatar
pdiggitydogg is offline
Old 04-08-2004, 12:10 PM
Default Re: DIY/How to: Del Sol Seats into an EK (citrEK)
I didn't think these are made by recaro (didn't see any Recaro marking on the foam or anything.)
I know some of the older Rex seats WERE made my Recaro, but if somebody can prove to me that these were that'd be cool. And I just started all of the bolts before I tightened them down and they're all in.
Old 04-08-2004, 12:15 PM
deeksmooth's Avatar
well i traded some 94 Sol seats w/ red stripe for the 97 w/ gray stripe.... i think recaro was stamped on the metal on the bottom of my 94 seat.
Old 04-08-2004, 12:19 PM
dunkd's Avatar
i have the same ones in my EG, grey stripe raised stitch....
heres cliffnotes... switch the del sol rails with your stock ones and plop the seats in
dunkd is offline
Old 04-08-2004, 12:22 PM
RaYnE's Avatar
good writeup
RaYnE is offline
Old 04-08-2004, 12:36 PM
alleyezonme's Avatar
Default Re: (RaYnE)
is the whole process the same for eg's??
alleyezonme is offline
Old 04-08-2004, 12:38 PM
DiRT!'s Avatar
didnt know it was that easy
DiRT! is offline
Old 04-08-2004, 12:47 PM
Default Re: (bumpincivic20)
Don't know. I've heard it is and heard it is'nt. I won't say either way because I've never done it.
Old 04-08-2004, 01:42 PM
elevatethis's Avatar
Nah you just got sol seats out of a black 92-95 sol......96-97 sols have no stripe and are made with a different upholstery
elevatethis is offline
Old 04-08-2004, 01:45 PM
NateTL17's Avatar
Did sols ever come in tan interior?
If not, what would any sol seats go with that color?
NateTL17 is offline
Old 04-08-2004, 01:46 PM
Default Re: (NateTL17)
I don't follow you.
The colors I have seen so I know they come in are
No stripe
grey stripe
teal stripe
red stripe.
There may be more, but those in my car are grey. Just a little dirty.
Old 04-08-2004, 01:48 PM
deeksmooth's Avatar
Default Re: DIY/How to: Del Sol Seats into an EK (elevatethis)
ahh, i am bound to **** up on explaining something... the only difference i noticed when swapping the seats was that my original seats w/ the red stripe, had a thinner, more silky material, where as my seats w/ the gray stripe has thicker material and more of a elevated burr burr feel... if that makes any sense.
Old 04-08-2004, 01:50 PM
VRD^don's Avatar
i wonder if they'll work on the crx seat too..
VRD^don is offline
Old 04-08-2004, 01:51 PM
NateTL17's Avatar
Default Re: (Ricey McRicerton)
I don't follow you.
No stripe
grey stripe
teal stripe
red stripe.
So they're all dark grey/black. Damnit. I hate my tan interior.
NateTL17 is offline
Old 04-08-2004, 01:58 PM
TSPeed Factory
AzntaggeR's Avatar
del sol seats will bolt right up to EG civics.
the seats also come in black/green stripe, black/blue stripe, and a very rare leather which i have never seen. also some of the black/red stripe seats come with different fabrics i've noticed.
AzntaggeR is offline
Old 04-08-2004, 03:50 PM
Civiclx's Avatar
yeah the red, green, and blue stripe ones feel like you are sitting on a cotton t shirt while the grey and no stripe ones feel like you are sitting on corduroy whales, much more grippy
Modified by Civiclx at 2:27 PM 4/10/2004
Civiclx is offline
Old 04-10-2004, 08:15 AM
toddbenson's Avatar
The seats come in the following colors:
Grey Stripe
Bright Green Stripe
Teal Green Stripe
Blue Stripe
Red Stripe
the 96-97 all a all black style pattern with thicker material. Only the all black and grey stripe style seat have the thicker material. the rest of the colored stripes have a thinner material.
toddbenson is offline
Old 04-10-2004, 09:12 PM
dunkd's Avatar
Default Re: (AzntaggeR)
after u switch the rails ofcourse.
dunkd is offline
Old 04-10-2004, 10:20 PM
overrated.
OnePointFive's Avatar
Default Re: (dunkd)
I'm on my 2nd set of del sol seats and i love them
best OEM seats IMO.
OnePointFive is offline
Old 04-10-2004, 10:27 PM
Default Re: (OnePointFive)
best OEM seats IMO.
You're damn right. You saw earlier I said I'd rock em over ANY other seat, reguardless.
Old 04-11-2004, 06:53 AM
slowhatch4now's Avatar
those seats are fawkin comfortable
just the stripe , ahhhh
peace
slowhatch4now is offline
Old 04-11-2004, 08:33 AM
Smith Wise's Avatar
Default Re: (slowhatch4now)
i see a lot of dx ek love on this thread...
rep it well...
nice write-up
Smith Wise is offline
Old 04-11-2004, 08:39 AM
nice write up ... imo really ugly seats ..... but nice DIY
1hotcivicSi is offline
RHD_BB4T
09-27-2006 09:16 AM
VTECorona
06-10-2004 10:44 AM
ej1times
04-25-2004 11:27 AM
Mentat Ghola
04-24-2004 01:48 PM
  • Ask a Question
Question Title:
Description:
