99-00 Si Spoiler Size
Anyone have a chart or measurements showing how long and wide the 99-00 Si wing is at the base (mount points)?
Also would it mount up in the same holes used on a 96-98 ex wing?
Always appreciated.
Always appreciated.
Darth ModerVader
Re: (SlammedSi00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlammedSi00 »</TD></TR><TR><TD CLASS="quote">Hummm... So would one fit my 94 EX? I have the smaller spoler that came on the 92-98 models I believe.</TD></TR></TABLE>
'92-'95 Civics were a completely different body style, and used different spoilers, so it's doubtful that it would fit.
Darth ModerVader
Re: (Vero)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vero »</TD></TR><TR><TD CLASS="quote">bump for the morning.</TD></TR></TABLE>
Measurements as promised from '99 OEM spoiler:
Note - "Front" means closest to front of car, "Rear" means closest to rear (obvious, I know). All measurements taken from bolt centers.
Distance between left and right <u>front</u> bolts: 46-3/16"
Distance between left and right <u>rear</u> bolts: 46"
Distance between front and rear bolt (either side): 1-3/8"
Distance between <u>front</u> bolt and front edge of spoiler's base: 4-5/8"
Distance between <u>rear</u> bolt and rear edge of spoiler's base: 2-1/2"
Re: (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">
Distance between <u>rear</u> bolt and rear edge of spoiler's base: 2-1/2"</TD></TR></TABLE>
Thats great, how about width on each side of the mounts?
Re: (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">You mean the distance from the bolts to the sides of the mounting surface?</TD></TR></TABLE>
if you look at it from the top the
| = side of car
[] = where the spoiler lays on the car.
_____ = seperatation
|[]______[]|
how long and wide is []
| = side of car
|[]______[]|
Darth ModerVader
Re: (Padawan)
OK, here it goes...
Photo of the actual spoiler. I painted the bolts with Wite-Out so they'd show up better:
My fancy diagram. Dimensions are lettered, and the key is below:
A: 46"
B: 47-7/8"
C: 1-3/8"
D: 46-3/16"
E: 46"
F: 9/16" (distance between center of bolt and outer edge of mounting surface
Some dimensions that I forgot to draw on the diagram:
Width of each mounting surface at widest point = 3"
Distance from <u>rear</u> bolt to <u>rear</u> edge of mounting surface = 2-1/2"
Distance from <u>front</u> bolt to <u>front</u> edge of mounting surface = 4-5/8"
A: 46"
B: 47-7/8"
C: 1-3/8"
D: 46-3/16"
E: 46"
Re: (Padawan)
very nice
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">OK, here it goes...
A: 46"
B: 47-7/8"
C: 1-3/8"
D: 46-3/16"
E: 46"
Distance from <u>front</u> bolt to <u>front</u> edge of mounting surface = 4-5/8" </TD></TR></TABLE>
A: 46"
B: 47-7/8"
C: 1-3/8"
D: 46-3/16"
E: 46"
94_civicEx
01-28-2007 03:30 PM
NitroSign
17
07-21-2005 07:58 PM
