non-terminating turn signals. Help
hey, I got a 96 civic ex coup with turn signals that won't terminate when the temp. outside is below 50 F. anyone know a fix for this? they used to work fine but a year ago, in the winter, they quit. let me know if you got the same problem.
Re: (pornstarSR)
i got the same problem on my 96 ex coupe, but it will work in any temp, BUT since i got it about 4 months ago, it has worked maybe 5 days but only in the late afternoon
Re: (DOHC4life)
i've got the SAME prob. in my 96 ex.... if its cold out, they wont turn off. if its warmer out, they're fine. if u figure out how to fix it, lemme know!
Location: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
Re: (JDMlifestyle)
There is some mechanical funtion that causes it to click back when you turn. Sometimes my EG civic likes to flip it to the other side when turning the wheel fast. Try and turn a little faster..
Re: (JDMlifestyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlifestyle »</TD></TR><TR><TD CLASS="quote">Junkyard is your best bet</TD></TR></TABLE>
i bet most autoparts stores can order a car specific one
Re: (dantastic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic »</TD></TR><TR><TD CLASS="quote">
i bet most autoparts stores can order a car specific one</TD></TR></TABLE>
yeah that's where I'd start too if you want a new one
Also I didn't know this many people had this kinda problem
Re: (HondaFanatic708)
they use a bi-metal strip... When the strip is energized, the dis-similar metal bends and opens the circuit, then when it cools off it straightens and closes the circuit again.
Re: (nickatiah)
ok, i talked to a tech at the local Honda dealership and he said alot of people have the same problem with there turn signals. My Gf's father's CRV has the same prob. and his was made in '96. also the tech i talked to had the same prob. with his car but it also affected his headlight switch on cold mornings. the part that needs to be replaced is called the headlight/turn signal switch and the dealer part # 35255-sr3-g02 and it costs $121! Maybe the junk yard isn't such a bad idea
Sloturd
01-25-2018 05:07 AM
Giantsfan2012
09-20-2014 10:49 AM
thefryer
05-22-2012 06:08 PM
