Teg seats
Re: Teg seats (StRacer)
if they are dc2 seats, 3 bolts will bolt up. But hopefully it should be secure. Im riding on only 3 bolts. You can always switch the rails with the ek ones.
Location: Why so you can pretend like youre interested, FL/OK
Re: Teg seats (DewMota)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DewMota »</TD></TR><TR><TD CLASS="quote">lol.. your only riding 3 bolts.. ghetto. It takes 3 mins to fix that. Just use common sense, don't be affraid to pickup a drill, or make a metal bracket.</TD></TR></TABLE>
I haven't determined what's worse, his 3 bolts or your idea to use a drill or make a bracket.
The seats are not going to be a direct bolt up. Switch the Civic rails with the Integra so the seats will be a direct replacement into the civic.
it depends on what year of integ, 94-00 integ seats only 3 bolts will bolt right away so you might wanna consider trader rails with your stock rails from ek,
and it will b the inner rail where the seat belt is thats the rail that you need to swap. after that your all good 2 go
Hatchtrap
10-29-2004 04:32 PM
