D15b swap
D15b swap
I am planning on swapping out my d15b7 with a d15b ordering it off of import-palace.com my frie4nds have told me that i can use my axles from my b7 but what should i use for the wiring harness? Is it ok to use a d16z6 harness? Any other info on this swap would b helpful. Thank you.
Re: D15b swap (Drew95eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spyderracing32 »</TD></TR><TR><TD CLASS="quote">its obd1 to obd1 u dont need a wiring harness except your stock one</TD></TR></TABLE>
all u need to do it wired vtec to ur vtec ecu.
Re: D15b swap (Ignitecivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ignitecivic »</TD></TR><TR><TD CLASS="quote">
all u need to do it wired vtec to ur vtec ecu.</TD></TR></TABLE>
yup what he said...
yup what he said...
Re: (Tad)
Yes i know i need a new ecu but that will come with it if i order from import-palace.com.. just wasnt sure about wiring the vtec or how hard that would be.
Re: (eg_6_racer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg_6_racer »</TD></TR><TR><TD CLASS="quote">Yes i know i need a new ecu but that will come with it if i order from import-palace.com.. just wasnt sure about wiring the vtec or how hard that would be.</TD></TR></TABLE>
ah its ez,
wires go from one spot to another,
with the d15b you probly only have to run 1 wire also, cuz it might have the pressure switch built into the ecu.
ah its ez,
handa
05-31-2004 07:42 AM
