96-98 2 door OEM power window conversion/install
1 Post
96-98 2 door EK OEM power window conversion/install
First off if youre afraid of tools or doing things the right way then you need not continue. This is a fairly big undertaking.
You WILL need::
96-2000 power window regulators
96-98 drivers and passengers door harnesses from EX coupe
96-98 floor harness from an EX coupe
96-2000 window switches
96-2000 EX interior door panels (or modify your stock ones somehow)
power window realy (honda part number Ill update later)
3 20amp fuses
and lastly an *** load of patience. A helping hand will make things go a little quicker. By myself and fairly good at this kind of stuff still took about 7 to 8 hours of my sunday. Also lots of parts and panels will be removed so have room.
This is a 100% oem install so no expence (time or money) was spared on this install. Does this mean you have to do your install this way? No.. but this is how Honda would do it... The right way.
Without further adue
http://repo.jackmoves.com/v/erik/album106/album206/
EDIT: we've been having server problems so its been up and down. If its not up when you try try again later.
EDIT: updated rear wiper information for anyone else swapping into a hatch.
Modified by monicle at 9:12 AM 7/16/2004
Modified by monicle at 9:13 AM 7/16/2004
Modified by monicle at 1:14 PM 7/20/2004
Modified by monicle at 8:43 PM 9/9/2004
Modified by monicle at 5:22 AM 2/11/2006
You WILL need::
3 20amp fuses
Re: 96-98 2 door OEM power window conversion/install (monicle)
I need to know what to do I have electircal doors and I used to have manual doors. I need to know how to wire it up so I Can use the power features
1 Post
Re: 96-98 2 door OEM power window conversion/install (Evil_Pull)
you need to get the floor harness and replace it so that you have the right connections to connect the door harnesses. Did you look at the how to yet?
the how to isnt working for me. can you possibly email it or something, I keep trying. jose @ promediacreations.com
1 Post
sirry. Its back online now. Our server guy was on his honeymoon when the crap went down but it should be up for good now.
Power Relay
Part number: 39794-S0K-A01
Honda code: 622878
Price: $4.73 x1
Mini 20a Fuse
Part number: 98200-42000
Honda code: 485344
Price: $0.52 x3
Honda code: 622878
Price: $4.73 x1
Mini 20a Fuse
Honda code: 485344
Price: $0.52 x3
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evil_Pull »</TD></TR><TR><TD CLASS="quote">where can i lookup part numbers like that?</TD></TR></TABLE>
You can look up part numbers here: http://www.slhondaparts.com
However, I don't know how to get the Honda code, but I don't think it is very important. Someone elighten us.
By the way, awesome how to. It is about time someone documented this entire process. Thanks, Monicle!
Re: 96-98 2 door EK OEM power window conversion/install (monicle)
i have a set of black 96-2000 civic 2dr. Doors have everything except panals and bottons $100 for both email or pm
1 Post
One problem found the yesterday. On the hatch after the conversion the rear wiper isnt working. This is because coupes dont have a rear wiper. Im going to rob the wiring and pins from the old harness and install them into the coupe floor harness. It will be documented on the how to in the very near future. Ill post when it has been finished.
1 Post
Re: 96-98 2 door OEM power window conversion/install (Petah)
all you need is the locks from an ex and they bolt right in and you hasy have to connect the electrical connectors. Ill get arround to buying locks and putting them in. Ive just been working on other projects lately.
