oil in a bad place?
oil in a bad place?
why is oil dripping down my intake tube? i went to replace the filter because its dirty and there was oil on the filter and in the tube.
why is this?
why is this?
did u do an oil change recently? maybe you over-filled. the oil is coming from the the hose where the intake is connecting to the vlave cover. check your oil level, get some cabeurator cleaner and spray your throttle body a little. clean it up
Re: (GUNNER666)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GUNNER666 »</TD></TR><TR><TD CLASS="quote">just checked and its overfilled
is having too much oil a bad thing?</TD></TR></TABLE>
yes getting oil into the combustion chamber is BAD!!!!!!!!
take off the intake and while the car is on spray some cabeurator cleaner into the throttle body, while turning the throttle a little.
after that should be no harm
Electrician
Re: oil in a bad place? (!EDWARDS!)
Yes, it's bad to overfill the crankcase. Remove the specific amount of fluid you overfilled with. Overfilling the crankcase can lead to MAJOR motor malfunction such as bent rods, etc.
Always check the level before you just dump motor oil in your crankcase. Drop in 3 quarts, add from there while continuously checking the level.
The oil in your intake pipe is a form of "blow-by". Jeep 4.0 motors are notorious for this due to the valvecover breather tube getting gunked by dried oil. This is a form of it.
Re: oil in a bad place? (Dimi)
My focus was notorious for doing this also it literally gunked up my AEM intake after a while and it wasnt overfilled, it just let oil in through the PCV pipe on a regular basis, what a POS dont ever buy ford, Im glad I bought a honda
cilvia
01-10-2008 12:38 AM
rayzian
16
08-17-2007 06:48 AM
